Salta al contenuto principale
What do I use to clean the LCD screen?
While replacing the outer glass panel, I got a couple finger smudges on the LCD screen. What should I use to clean the LCD screen?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Risposta Più Utile
Spray some windex on your cloth and then clean it. Never spray cleaner directly on to an electrical device.
Punteggio 1
1 Commento:
/* gays,,,, that finger prints are inside of the panel.. u giving suggestions to clean out side of the panel.... */
for cleaning inside of the panel, it should be remove once again the panel and clean it carefully.
Punteggio 1
Let's try the world's first anti fingerprint coating kit ' Fusso SmartPhone' that let you reproduce touch screen anti fingerprint oleophobic coating as same strength as manufacturer's original coating.
( www.apeiros.jp/Fussode_COAT_2 or find it on amazon.com )
Punteggio 0
Aggiungi la tua risposta
stsams sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,714
