Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2694 Domande Visualizza tutte
Why is my charger not charging my cellphone any more then 9%
I have had it plugged in for 24 hours & it has been either:
• Reducing the battery while charging.
• Keeping it at the same percentage.
• Giving it one percent in like 4 hours
- It has been stuck on 9% for going on 6 hours & I am unable to take it off of the charger or it drains from 9% then dies within 2 minutes of me not using it?
Questa è una buona domanda?
Punteggio 1
1 Commento:
Do you use original charger or apple certified one? does phone getting hot while charging ?
da
Aggiungi un commento
1 Risposta
Hi Trinity McQueston ! If you are using the original charger it is definitely a faulty battery from itself. Check by using another charger and if the problem continuous you must change the battery.
Punteggio 0
Aggiungi la tua risposta
Trinity McQueston sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 336
