Salta al contenuto principale
The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
106 Domande Visualizza tutte
Domanda Chiusa
Super Nintendo - only white snow on the TV screen
I have a 20-year-old super Nintendo that just stopped working recently. I was all excited to game with my friend who was over and the super Nintendo no longer even comes close to loading. The channel is set correctly on the back of the consul and the TV and it's a recently worked as much as two months ago. Now there's just white snow and it does not even come close to loading tried multiple games, tried vacuuming out the system and game cartridge but I'm afraid something is jarred loose and it's just broken completely. Suggestions? I'm about to order a screwdriver to start working on it and see if there's anything I can do. There does not seem to be any damage from the outside and there's no noises from anything moving around that could be broken.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Nevermind, it is firing up now it was a power issue, my SNES is being AC power choosy, some powerstrips I have are not working with it. I had to use the vacuum on it more to get more dust out of the pinstrip and cartridges as well. I highly recommend using a clean narrow vacuum tip to get excess dust out of the Super Nintendo as it accumulates quite easily. However, do not make the same mistake that I did... do not closely press the vacuum tube on the back of the machine ports, the AC plastic pin can come out completely with enough suction and be replaced, but I am not going to unplug it anymore.
da
Aggiungi un commento
1 Risposta
Try taking a matchbook and lightly rubbing the contact points on both game and system this may clean debris burned on during game play
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 641
