Salta al contenuto principale
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
installing OS on new HD
Hi;
I installed a new harddrive in a mc mini I got off e-bay. I was using superduper to clone the original HD, but it seems to have crapped out and just keeps clicking and not spinning up.
I need to install the OS on the new HD, but the mini did not come with install discs.
I do have a legal version of the 10.5 install disc - so my question is: how can I install os 10.5 on the new hard drive (formatted by attaching it to another mac)?
Should I reset the PRAM and replace the little backup battery on the main PCB?
THanks
Update
I should have aded that I also swapped out the old combo drive for a new superdrive. Apparently the superdrive is not so super and wouldn't read the OS X install disc. Need to troubleshoot the drive to make sure it's not DOA.
Questa è una buona domanda?
Punteggio -1
2 Commenti
Jens, u have to keep the "C" key pressed....not tap it repeatedly.
da
I did. For some reason it didn't work with the new DVD drive. I had to reinstall the old drive to get it to work. Thanks for all the help, though.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Start your Mac from the 10.5 DVD by holding down the "C" key. On the second screen select Disk Utilities from the Utilities menu. Format and/or partition the new drive. Then you are ready for a fresh install. Good luck.
Punteggio 3
3 Commenti:
I keep pressing the C key on the keyboard, but all I get to is the screen with the flashing folder/question mark. And I also can't get the install disk out of the CD drive.
da
Aggiungi la tua risposta
Jens Mueller sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,462
