Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
screen dimmed out itunes cant access
my iphone 5c screen was working fine and then the screen went dim to black and never came back up. i opened it to check the wires and everything was fine, i connect it to my pc and after about 3 minutes it will recognize it so i decided to put it into restore mode, it does but then itunes says to allow access to iphone respond from iphone..... thats as far as ive gotten. i downloaded a previous ipsw and all i get is not compatible with my device. should i buy a new screen? should i buy new parts? this will be my 2nd screen ..... the original cracked and i replaced it with no issues until now.
no water damage either.
thanks.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Have you tried putting it into DFU mode?
Punteggio 0
4 Commenti:
yes i tried but since i cant see anything i just settle for anything which is usually restore mode.....also it comes up as iphone not my usual iphone name
da
Ok, than try reconnecting cables of your old LCD and touch. If that wont work, try replacing it with the new one. Its pretty easy and you have all the guides here on IFIXIT.
da
the old one is only the wires .... the screen shattered and wires broke off..... i guess i'll buy a new one thanks
da
Thats the way to go! You're welcome!
da
Aggiungi la tua risposta
g121390 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 62
