Hard-drive not spinning up at ATA100. Need new LogicBoard?
Hello everyone,
I've got a MDD (DP 867 / 133MHz FSB) with a harddisk not spinning up when connected to the ATA-100 port. At the ATA-66 it spins up , but no target disk function / no boot up. When placed into an external hard-drive bay it works fine.
LogicBoard issue ?
If so ..
May it be possible to fit a FW800 LogicBoard (1474a) into a MDD with an installed LogicBoard "820 - 1380-A" ? Cutting out that port being compulsory . Are there compatible LogicBoards to fit in (eg. 820-1453a)?
Regards Jan.
Questa è una buona domanda?
2 Commenti
Supplemental.
The system does seem to not respond to ANY inputs from keyboard, caps lock not working, fans speed up, heat-sink get warm after some time.
da Jan Bernert
All the mentioned steps would be helpful if only ribbon cable / harddrive or PMU error where present. This is obviously not the case here.
Closed.
Thanks for you contributions, much appreciated .
Jan.
da Jan Bernert
