Salta al contenuto principale
Repair manuals and support for cars and trucks manufactured by Chevrolet, a division of General Motors.
key stuck in ignition of old truck
The ignition key mechanism won't turn off or release key. I have been removing fuse to shut her down... It is stuck in "on." Turning of the steering wheel to relieve locking does not seem to help.
Any suggestions would be appreciated
Scott
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Have 88 gmc truck key stuck in ignition in on position and won’t come out tried everything disconnected battery to start power
da
I've had the same thing happen, I've had luck twisting the key partially int the start position the back to off. the permanent solution is a new ignition cylinder
da
Aggiungi un commento
3 Risposte
Depending on the year there is a small hole which you stick a paper clip into next to the key hole. Pushing the clip in and turning the lock set toward accessory will allow the whole lock set to be removed.
Punteggio 0
1 Commento:
Then you can push the key out from the back side of the lock.
da
Some old cars with the key on the steering column would ‘lock’ the key in if the wheels were turn all the way to the left or right, such as when parallel parking. You had to pull the steering wheel real hard in the opposite direction while simultaneously turning the ignition.
Punteggio 0
1 Commento:
Have 88 gmc truck wheels r straight and turn and key will not turn off
da
Do as Frankie advised you, I had the same problem a few years ago and that did the trick.
Punteggio 0
2 Commenti:
My "new" 88 GMC C1500 just started doing this. Will the steering wheel yank work forever or do I need to replace ignition or...?
da
How do you fix that on 1998 silverado c1500 have to turn wheel Wich is hard all the way to the left to turn over the key and when you do hearing clicks
da
Aggiungi la tua risposta
redhare sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 48
Tutti i Tempi: 14,588
