Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
1697 Domande Visualizza tutte
New USA Model CUH-1215A teardown?
Hi iFixit,
When do you expect to have a teardown of the new CUH-1215A PS4? I expect that it is similar enough, but I noticed that the HD screws are in slightly different locations. I would like to replace the thermal grease on mine as the fan is a little loud when gaming.
Thanks
Questa è una buona domanda?
Punteggio 7
17 Commenti
I am looking to tear mine down tomorrow. I just purchased it and would like to apply AS5 and stiffen the clamp holding the heatsink against the APU
da
Cool. Take pictures and post your guide. : )
da
I'm needing a power supply and can't find any help
da
What type of power supply do you need? 4 wire or 5 wire?
da
I need a cuh1215a power supply can r commend where I could buy one or could I use a different model power supply?
da
Mostra altri 12 commenti
Aggiungi un commento
2 Risposte
Soluzione Prescelta
We at TronicsFix just posted the teardown for this a few days ago: CUH-1200 Teardown
I hope it helps!
Punteggio 13
6 Commenti:
I finally bought the power supply for the cuh1215a model is this the same way to open the ps4
da
To replace the power supply you just need to remove the bottom plastic. Then the power supply will be right there under it.
da
Well done TroncsFix. This is the way to SPAM and help others at the same time, very acceptable ;-)
da
Not sure how you consider this spam. Posting a teardown of the newest model PS4 seems like a pretty helpful thing to do. Was there somewhere in this teardown that we put links to anything of ours?
I think comments on these questions are better if they bring value to ifixit visitors, I'm not seeing how yours does.
da
Would a T8 torx work instead of T9?
da
Mostra 1 altro commento
My ps4 the HDMI cord was pulled out so i tryed other ones and for some reason it dont want to work the box it shelf does come on cuz the blue light comes on but for some reason on the tv it dont idk what to do
Punteggio 0
1 Commento:
Does the light ever go to white?
da
Aggiungi la tua risposta
Dave sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 180
Tutti i Tempi: 34,529
