Salta al contenuto principale
La Canon PowerShot SX280 HS è una fotocamera compatta punta e scatta da 12 megapixel con super-zoom, dotata di un'escursione ottica 20x, Wi-Fi e GPS integrati.
Doesn't recognize fully charged battery
the camera does not recognize fully charged batteries. I have purchased a replacement battery thinking that the battery may have been the problem, but the camera does not recognize either. Even with two fully charged batteries I am unable to take a photo.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta più utile
There is a real good video on you tube so cant take credit for this but essentially all you need do is put a piece of tape over the central terminal of the battery and this will fix the problem. Rember to remove it prior to charging the battery though.
Punteggio 1
1 Commento:
The model I had ended up having a recall if the battery contact point. Sent it in and canon sent me a replacement camera.
da
Punteggio 0
Aggiungi la tua risposta
Julia sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 6
Tutti i Tempi: 789
