Salta al contenuto principale
iMac G4 17" 1.25 GHz Model M9168LLA PowerMac 6,1 introduced in 2003.
superdrive, hard drive and memory replace and upgrade
Has anyone attempted to take apart the iMac G4 17" 1 Ghz model. My DVD drive died and I figured while it is open upgrade everything I can. I have spare 1GB DIMM ram, spare 250 GB Hard drive and spare DVD drive, also that thermal paste. Any advice will be helpful, and if anyone has a step by step guide with pictures will also be appreciated.
Thank you.
Update
The upgrade went flawlessly, the machine is performing better than before.
FYI to install a OEM DVD/CD burner you must remove the entire plastic faceplate of the drive case.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Here's a 24 page instruction guide on the optical and hard drive replacement. This is one of the most difficult machines to work on that Apple ever made so take your time: http://www.faqintosh.com/risorse/en/guid...
Make sure you have the correct RAM, ATA/IDE hard drive and optical that will work.
Punteggio 2
1 Commento:
Beat me again--here is an additional link to help. + Ralph
http://www.xlr8yourmac.com/systems/iMac_...
da
Aggiungi la tua risposta
Dinowarrior18 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 6,030
