Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Domanda Chiusa
My iPhone stuck on apple logo (it wont recoverymode or dfu mode)
Hi guys
I really need your help Im iphone is stuck on apple logo for 5 days now!! i already put it on rice but it still doesnt work!! it happend last monday when i left it on my bag with a bottle of water and when saw it i immediately dry it of and IT WAS STILL WORKING but when I got home It was dead!! it doest work anymre! (i thought it only had low battery but when i charged it, it stuck on apple logo for 30 sec then it switch off then the apple logo again same thing when I unplug it.. i tried to dfu mode or recovery mode but still on apple logo
i reaaly need you help!! PLEASE
sorry for my english
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
The biggest mistake people make when they get there phone wet is they continue to use it or plug it in to a charger. Its an electronic device that has water on it, it needs to be cleaned and dried out before it can be used. My suggestion would be to take it to a repair center that offers a water treatment process and see if they can get it back to working again. More than likely something got fried on the logic board from being powered on & then plugged in while still being wet.
Punteggio 2
cathrainz, follow up with what TechyGirl suggest. Otherwise you can try this. Number one rule, SKIP THE RICE. It does not do anything. Absolutely nothing. With any water immersion what you want to do is to not try to restart/sync the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides. You must remove all the EMI shields of the logic board. If you do not remove those you are not cleaning 3/4 of the board. Clean everything with +90% (no less than 90%) isopropyl alcohol. Follow this guide, and even so it was written for a 3G all the points are still pertinent to your phone. Pay particular attention to the SMD components, check for charred missing or broken missing. You can then dry the board in an oven or equivalent at 220deg F (not higher;-) for a few hours. Best way to clean it would of course be through an ultrasonic cleaner. Consider professional help with that When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate.
Punteggio 2
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 197
