Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
No display after routine thermal compound application.
My macbook pro was overheating so decided to open it up and reapply thermal compound to the cpu. That all when smoothly but upon closing up the unit I noticed a burning smell coming from the machine. I opened it up and realised that some components near the lvds had literally come off. I can't find the schematics for this machine and I have spent countless hours hunting and no joy . Its emc is 2554 . Has anyone every had this problem and how did they over come it? Seems a pity to just buy a new one. The machine makes all the noises on startup. Any help would be great appreciated. Cheers
Questa è una buona domanda?
Punteggio 1
2 Commenti
The schematic is SCHEM,MLB,J30 your board version is 820-3115 keep hunting !
da
Thanks John. Have managed to find the schematic. Will attempt the repair. I have nothing to loose as its dead at the moment. Besides am pretty good at soldering so will give it a bash. Thanks again. All the best.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Looks like you got components burnt L9004 and C9015 they are on the line of PP3V3_LCDVDD_SW 3.3v but instead of just replacing them you need to find out why and how they burned in the first place it may do it again you probablly broke one off one the components by accident which is a good chance then a simple replace of the components may do the job you need also to take voltage from that 6 legged chip sort of close to the Plink Fuse U9000 also go to capacitor C9012 and see if your getting 3.3v there.
You could alternatively start with replacing Inductor L9004 which is a 402 package @ 120 ohm 1.5amp and cap is a 10uf 6.3v in a 603 package you can get them from digi key or mouser also pins 2 and 3 look a little dark on the lvds connector you may need to inspect and touch them up a bit.
If your really serious about repairing this search a1278 no backlight etc on youtube you find some professionals in action it's 2 part really the hunting troubleshooting and the physical reworking of the board.
Punteggio 2
1 Commento:
John,
I have the same/similar issue with a neighboring component. It is the black one (below the brown one) to the left of the burnt area. Can you please help identifying it? I will try to post a picture of it.
Thanks.
da
John,
It is the circled one in the attached photo.
Thanks!
Ibo
Punteggio 0
Aggiungi la tua risposta
Zane Ali sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 302
