Salta al contenuto principale
Repair guides and support for DVD players manufactured by CyberHome.
Why after inserting a DVD appears on the screen BAD DISC?
When I insert any DVD, after the charging time, BAD DISC shown on the TV screen
Questa è una buona domanda?
Punteggio 3
1 Commento
same here bad disk yet another old video disk plays fine
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hi @sevenofnine ,
Have you tried another disc, in case this one is scratched or faulty?
If you have and it still doesn't recognize the disc try cleaning the laser lens in the player.
Here is a link to the ifixit CyberHome CH-DVD 300 Disc Tray Bracket Replacement guide, which will help gain access to the laser lens.
There are videos online that show how to clean a DVD player (or laptop dvd drive- same principle) laser lens using Isopropyl Alcohol 99%+ (available at electronics parts stores) and a Q-Tip.
Punteggio 3
IMPORTANT ! ! !
If you keep getting the "Bad Disc" error, just do as follows"
1) Push "Set Up" on remote
2) Use arrow to get to "System" and push "Enter"
3) Use arrow to get to "Reset" and push "Enter"
Punteggio 0
3 Commenti:
i went back to the DEFAULT setting, but it still came up BAD DISC, there does not appear to be a RESET function on my portable dvd palyer.
da
same here sm
da
If the cleaning the lens does not help (and that's Windex or vinegar thing on a Q-tip and dry it with other end of Q-tip - or there are dvd's that are cleaning dvd's but be careful not to get a blue ray dvd cleaner... watch label).
If cleaning lens does not work, go back into dvd player and adjust the speed ever so slightly... see if the reading comes back.
da
This could be a bad disc, if you have tried to insert other disks and it comes up with the same result it could be a hardware or software or lens issue
Punteggio 0
Aggiungi la tua risposta
stepslonely sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 19,824
