Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
Small segment of screen is unresponsive
Hello, I've had my phone for about a year now, and my phone was dropped with a tiny crack on the screen, but my phone was working perfectly fine. Ever since I downloaded iOS 8 there is a small part of my screen that doesn't respond to touch, it's just below the middle of a phone and it's horizontal across. My screen was replaced yet I'm still having problems, my guess it is that it's the iOS software being corrupt, I spoke to an apple guru and he said he had a problem with his iPad being the same, he told me all I had to do was restore my phone through iTunes, I went through either the procedure and my screen is sti unresponsive.
Any ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Cameron,
This is usually caused by damage to the Digitizer. Although you have stated that your digitizer screen was replaced so the only other problem I could think of would be the connector for the digitizer. It is unlikely this is an issue with the iOS software. I have done at least 2 4th Gen iPod Touch and 3 iPhone 5 repairs with the same issue and they have all been due to a cracked screen of damaged connector. All have been repaired and returned to my customers without any issues after replacing the damaged parts.
Good Luck and I wish you the best!
Punteggio 1
Sounds like you have a faulty digitizer, I would highly recommend getting the screen replaced. This should solve the issue you are having. :-)
Punteggio 1
Aggiungi la tua risposta
Cameron Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 80
