Salta al contenuto principale
Tutto quello che ti serve per riparare stesso il tuo iPhone! Dal nuovissimo iPhone 15, fino all'iPhone 2G originale del 2007, iFixit offre guide di riparazione gratuite e informazioni sullo smontaggio per ciascun modello di iPhone, oltre a fornire le migliori parti di ricambio, strumenti e consigli della galassia.
36478 Domande Visualizza tutte
I cant open my iPhone,how to fix it?
i cant open my iphone..the only thing i can see when i open it is the apple sign and black screen,how can i fix this?
Questa è una buona domanda?
Punteggio 58
20 Commenti
now i have a trouble in touch screen i can't inter the pass cod to open it i guess there is something wrong in the screen but in the same time i can answer the calls how that i don't know
da
my iphone5 suddenly off , and then i can't open it . i try to press the sleep/wake button but still it don't work , even a light it won't show , even i charge it , it does'nt show any light . pls help me . Vincent from Philippines
da
i can't open my iphone5 ,i try to reset it but the only thing i can see is the apple sign and black screen...please help me. Deejhay from philippines
da
my iphone 5s clone is cant open apps
da
my iphone5 suddenly off , and then i can't open it . i try to press the sleep/wake button but still it don't work , even a light it won't show , even i charge it , it does'nt show any light . please help me please
da
Mostra altri 15 commenti
Aggiungi un commento
4 Risposte
Soluzione Prescelta
what iphone do you have ?
i would first try to reset it - press and hold the sleep and the home button at the same time until the iphone restarts - if that won't help - connect it with the computer and start itunes, does itunes show any error ?
if the isn't recognized by itunes, put it in dfu mode and restore it
if you don't know how to put it in dfu mode - here is a HowTo video on youtube
good luck
Punteggio 58
41 Commenti:
100000000 thank to you Mr.markus weiher ^^
I had the same problem.
da
i switched off my iphone 4s for a while. when i tried to open it, it didn't work. i connected it to my laptop and it switched on but the only thing i saw was a black light on the screen without the apple on it. then i pressed and held the sleep and home button at the same time And it worked, the apple appeared and finally i went back to business.
Thanks to Mr. Markus Weiher
da
thanks a lot markus its 101% working..u save my day..
da
thank you so much, Markus.. i had the same problem.. and, with your help, my iphone is working & no more problems... u save my day :)
da
ohhh my god.. ill try what you said.. ill try to hold the reset and home pages at the same time,, then after that ill wait a few seconds its work wow thank you verry muchhh
da
Mostra altri 36 commenti
Thank a lot. it worked like magic
Punteggio 0
My iphone power button isnt working how can i reset without that?
Punteggio 0
My iphone 6s displays everything but will not open, its frozen. it earlier displayed that iphone is full but it will not move . i have tried top right button and home button at the same time it wont work! PLEASE HELP
Punteggio 0
Aggiungi la tua risposta
donesa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 123,327
