plastic camera bracket removal
How do I get the small plastic camera bracket off my old screen and back on my new screen?
Questa è una buona domanda?
Hi Jason,
The easiest way to remove the plastic camera bracket, is to get a heat gun or reflow station and go over the front of the screen, this softens the glue and allows you to easily remove the bracket. :-)
Use hot air (100-200 deg C) for 20-10 seconds, the pry off using fine tweezers or a needle. Be careful as it's springy.
Next to it, there is a tiny square piece of white plastic, make sure to transfer it as well.
HEAT works best i usually lightly scrap the glue with a sharp knife
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 78
1 Commento
Thank you, worked great
da Jason Hammond
