Salta al contenuto principale
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Domande Visualizza tutte
Assembling after Logic Board Replacement
Hi,
Im replacing logic board in an iPad Mini 1. Originally the board is stick with sort of metal tissue pieces to the bottom of the device, I suspect metal is used deliberately :).
The problem is those metal things is quite difficult to re-use, what would you do? Metal scotch is quite expensive and using foil just looks wrong...
Questa è una buona domanda?
Punteggio 0
2 Commenti
Another question is if it must be electrically conductive or just heat conductive...
da
Do you think if http://www.aliexpress.com/snapshot/67551... could be suitable?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I used eventually https://www.aliexpress.com/item/6mm-20M-...
Punteggio 0
I think it's there for the heat, like you said. I've assembled them without it, and it works fine. But, like you said, the tape isn't cheap. They aren't putting it in there for the !&&* of it. I'd try reusing it if you can...
Punteggio 0
1 Commento:
Im not totally sure its just for the heat... Lightning cable has the same contact areas as the board, but I doubt it heats up...
da
Aggiungi la tua risposta
Maaaah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 89
