iPhone 6 Screen Replacement
After fixing glass-LCD combined screen on iphone 6 or iphone 6+ sometimes the glass gets out of holding frame after a couple of days. how to fix this problem?
Repair Stop
Questa è una buona domanda?
Repair Stop
Yup, this's a common problem reported by many repair shops, check it below for the reasons behind and the solutions for iPhone 6 separated from LCD.
Nice article. Thanks Mandy.
It's quite sad that hardly any suppliers are getting good quality screens.
Using poor hot melt glue, thicker frames which don't sit flush in the phone and make it look terrible, a lot of the times the frame itself lifts by the mute button causing the LCD backlight to show through the side and it's expensive to, if I was a customer paying that much cash, I would be seriously !#^&@@.
I don't think hardly any of us have the right to fix the iPhone 6 or 6 plus till parts get better, considering Apple do it cheaper and obviously have original parts.
I don't even bother with the iPhone 6 at this point, just send the customer to the nearby Apple Store. The horror stories on here about the quality of the replacement parts for the 6/6+ are astounding.
I hear you Brian, I've ordered from this China company, if the quality isn't as good as original, I'm going to give up doing the 6, i haven't done them in a while, so I am trying this one for this woman, I said to her, if this part is trash, I will put original screen back on and she can take it Apple, so I will be using gloves to stop fingerprints on inside, so Apple can't turn around and say it's been tampered with!
Many parts of the world don't have Apple Stores. Some of those have Apple Certified Service Centers, but have not yet seen an Apple Certified Service Center in this area that carries original screens. They also buy China trash.. Thus in our case the only option is those sketchy quality screens that we have to put up with. Usually, the LCD and touch are good enough, the main defect being the frame separating from the assembly...
If you can't find a better supplier or better quality screens, trying adding some glue to hold the frame to the glass. I do this sometimes, using tiny amounts of glue.
Be very very careful not to let glue get into contact with the LCD and Backlight panels.
If you're referring to refurbishing screens, can't suggest anything since I don't have experience with refurbishing.
There are 2 reasons for this problem:
1. Glue
2. Frame
Check more details here: Problems with iPhone 6 LCD screen replacement
Stop using the cheapest screens you can find. Use screens that have cold pressed frames.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,695
