Salta al contenuto principale
Compact blender made by Homeland Housewares
9 Domande Visualizza tutte
smoke and burning smell was coming out of my magic bullet
Hi
Some kind of smoke and burning smell was coming out of my magic bullet.It happened at my first time use.
Am I need to buy any special adapter for power , ?
Please advise am not in USA for repair and replacement.
Need your help to use my magic bullet properly.
Thanks in Advance
Srinath
Questa è una buona domanda?
Punteggio 4
1 Commento
My magic bullet has done this in the past when I put too much liquid/food in the cup. There is a line on the cup that indicates the maximum fill level.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
We have one of these and when ours did this it was because we overloaded it with stuff that it couldnt handle or we pack it in to tight. My suggestion to you is to clean it out and run it with just water in it and see if it works right if it still smokes then you toasted it.
Punteggio 5
How did you fix it?.. did you ruined your magic bullet?
It happens to me too few minutes ago..Im so angry
Punteggio 0
I too faced the above issue yesterday, i purchased it in US and using in Singapore. I took the voltage converter plug too but i hear a sound and smoke came out of it in 1st usage, i am pretty worried if it will work or not ? Any suggession ?
Punteggio 0
Aggiungi la tua risposta
srinath sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 20,393
