Salta al contenuto principale
The third generation of Galaxy Tab including a 7.0, 8.0 and 10.1 inch display versions, as well as the Galaxy Tab 3 Lite 7.0. Released in July 2013.
Why is my screen flashing (samsung galaxy tab3)
my samsung galxay tab 3 has been working fine all day now all of a sudden its turned of but flashing (samsung galaxy tab 3) or if put on charge will just flash the empty battery symbol whats wrong?
Questa è una buona domanda?
Punteggio 3
1 Commento
were will i find the battery in the tablet
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Have you tried taking the battery out.then put back in and put on charge for 1 hour. Don't try to boot until it has a good charge. I think it's a super flat battery...hence it can't boot.
Punteggio 1
2 Commenti:
Don't do that as you device having non removable battery. if you don't have good knowledge about high capacity Li battery handling, be careful!
da
Actually it is removeable. Difficult but doable depending on which tab he has. My mistake I misread and thought it was a s3...however the symptoms are the same..super flat battery.
da
Leave the tab on charge at least 3 Hrs and turn on and check whether same fault can be observed.
Punteggio 0
probably there is virus within .
Punteggio 0
1 Commento:
@fallenangel0901 how do you fix that? Why would a virus cause this?
da
Aggiungi la tua risposta
kingsthorpejetsmad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 15,333
