Heating and Switching Off
MY phone gets heated and Switched off continuously mostly during video calling.
Questa è una buona domanda?
Video call required high level resources and at that time your phone preform it's maximum and cause to produce heat. if you are yous in poor coverage location producing heat can be higher than normal but restarting means there is something wrong in the system. if you feel abnormal heat during the long use you may have to start diagnostic in the motherboard otherwise replace the battery and see. most probably your fault can be solved
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 73
