Salta al contenuto principale
Repair guides and support for phones produced by the South Korean phone and tablet manufacturer, Pantech.
13 Domande Visualizza tutte
Dropped my phone in salt water. help!
Hello.
I dropped my brand new pantech link phone into the ocean about 12 hours ago. It only took a dunk, fell from my pocket. I tried to put it in rice and let it sit for a few hours. When I put the battery in, the keyboard lights up. Then if i press and hold the end key, it turns on like usual. Then when it gets to home screen, i cant open anything. my buttons dont work. i can get calls and text messages but cant answer or open either of them. they screen and keyboard stay lite until i take the battery out and try again. i have tried to charge the phone but nothing. any ideas on what i should do, or help me fix this?! please and thank you so much
Questa è una buona domanda?
Punteggio 8
3 Commenti
good that i don't have to understand everything - have fun with your new phone
da
My redmi not 4 fallen in sea water and it not working from one year tell me the situation how it can work
da
My iphone 6 was submerged by ocean salt water and after rice treatment over night, I am unable to turn on. What are the changes my phone is no longer operative?
da
Aggiungi un commento
8 Risposte
Soluzione Prescelta
first of all - don't put the battery in the phone!!
forget about the rice, disassemble the phone asap - and with asap i mean NOW!
salt water is very corrosive and the only chance to save the phone is cleaning it.
take the logic board and clean it first with distilled water and a paintbrush (i know it sounds stupid, but the salt must be removed)
i didn't find a teardown or something else, but it should not be that big problem to get this device apart.
after the first cleaning, use a different paintbrush and isopropyl alcohol to clean the logicboard again, let it dry after that.
when it's dry, check the board for white/greenish residue - if there is any - clean it again with the alcohol
clean all connectors too - dont forget the keypad and other switches that the phone could have - the only thing that not has to be massively cleaned is the lcd - that would most likely die - but the contacs ot the lcd must be cleaned too
let it dry disassembled - don't use a hair dryer (a day or two are enough)
then reassemble it and try to power it on
good luck
Punteggio 14
11 Commenti:
Agreed.
da
thanks, im trying it right now. hope it works!
da
good luck, but it was a little bit strange that you first accepted my answer and then osvaldo's answer. that's why i wrote the comment above
da
Mostra altri 6 commenti
Salt water is an electronic KILLER.
Not only is it highly conductive but it’s also very corrosive. So even if your phone does work after it has had time to dry you might run into some serious problems later on down the road. You want to get that salt water out of your phone as best as you can.
I would suggest that you follow all of the advice listed at How to save a phone dropped in salt water but basically…
  1. Remove the phone from the salt water as quickly as possible.
  2. Fill up a container that your cell phone will fit into with isopropyl alcohol (I highly suggest that you use 99% alcohol).
  3. Submerge your phone in the alcohol and try to get the alcohol to go into the phone and try to get the salt water out of the phone.
  4. Let your phone soak in alcohol for a good hour (or more).
  5. Remove the phone from the alcohol and then dry it by hand as best as you can.
  6. Let it sit and dry in rice until the phone is completely dry (this could be over night or a couple of days).
  7. Put the phone all back together, cross your fingers, turn on your phone and see if everything is still working properly.
If it is then enjoy your working phone if it isn’t then parts of your phone may have been damaged and those parts or the phone itself will likely need to be replaced.
Punteggio 3
5 Commenti:
Instead of using 99% alcohol should I buy a new motherbroad
da
What should I do I was taking photos with my new I phone x and I dried it and put it in rice and a day later still not working what should I do!!
da
I'm assuming cause of this was liquid damage, If that the case immediately turn off device and take it to a local logic board repair shop and have them clean board or if you experience enough separate logic boards and desolder shields and clean board with isopropyl alcohol. THIS IS ONLY WAY TO PROPERLY CLEAN YOUR PHONE! *These steps are only for iPhone X, steps for other device may vary.*
da
hello. I did not know it. yesterday my pixel XL fell down to the ocean. it took just 1 minute to find it. my phone was on and working all day long but today does not turn on anymore. i tried to charge today it but it didn't. what should I do?
da
My phone is still alarming... The prob is that it doesn't have the display.. I would try to clean it with alcohol.. Then comment again.
da
I dropped my phone in slat water ages ago and i let it dry out but i didn't end up working so i sent it away and they couldn't fix it.. I was wondering if I can still get it to work? It's a Sony Xperia S ( I think)
Punteggio 0
I know this is late but just wanted to show what can happen when you drop it in salty water and don't clean it instantly. This is a Galaxy Alpha dropped in the Mediterranean Sea (saltier than the Atlantic) and left to dry for 4 days (had no tools to disassemble it until I got home).
https://dl.dropbox.com/s/lf9uwlbobpve6pm...
Note the black stuff on the left part (that's the lcd, upside down, should be all shiny bronze), the white power stuff on the right, etc. Corrosion got to it in a hearth beat. This phone is most likely beyond repair.
Punteggio 0
Dear Admin
Last weekend i went to honey moon using wiko hand phone was drop at water, unable to ON feel regret and couldn't retrieve the photos back. Thanks Wiko phone producer it wouldn't get memories after using nonsense phone which is battery has been connected to motherboard...
While produce the phone they should fine alliterative solutions if accidentally drop water should take out battery. Unfortunately not at all. Once again thanks to producer for the phone wiko
Punteggio 0
1 Commento:
Dear Admin
Anyone of you can really help me hoe to retrieve the photo in phone.
da
Hi,
My phone was in my pocket at the beach and my friends pulled me into the beach and my phone got wet in the salty water it was working though throughout the day also i charged it. then the other day when i again tried to charge it wasnt charging it was showing charging but suddenly would again show not charging this was continuously happening so unplugged and kept dry throughout the day then at end of day again tried to charge then as phone battery was dead.Unfortunately it just blinked but not started.
Now gaved to repair lets see if any possibility it gets well :(
Punteggio 0
my phone nova 2i fell in the water salt and i dont know how to fix this my mom gonna kill me about this
Punteggio 0
You Need To Let It Set In Rice 4 Two Days My Sister Did The Same Thing She Has The Same Phone And Now Hers Works Perfectly
Punteggio -1
3 Commenti:
and if it does not get cleaned properly after, it will suffer failure from corrosion damage down the road. The rice is a good first aid, but it is not a permanent fix ;-)
da
I cleaned my huawei that was dropped in saltwater..I let it dry and by the time I plugged the charger..I did see then start up logo for about 3 secs and it was gone and have no display, but when I tried to press the power botton I can feel the vibration but no display...can you help me please see....ty
da
Dorian, never look at the display. You might not like what you see.
da
Aggiungi la tua risposta
marissa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 175
Ultimi 30 Giorni: 739
Tutti i Tempi: 134,721
