Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
iPhone 5c wont charge, dock connector has been replaced?
Hello
I have got an iphone 5c which simply wont charge, i have replaced the dock connector, and the same problem occurs, the phone works perfectly otherwise, and all of the other parts of the dockconnector like the jack port works perfectly.
Can it be a problem with the motherboard, and could cleaning the connection on the mother board with alcohol help?
I simple just don't know what to do, hopefully someone in here has some insight
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Jonas Paarup, replace the battery as well. If it still does not charge, and you are sure the replacement Lightning connector works properly, you are having issues with the power management IC on the logic board. This will be a very difficult repair and requires special tools and skills.
Punteggio 0
1 Commento:
I have already replaced the battery too. And i have tried 2 different Dock connectors, so i am pretty sure they work. I guess there is nothing to do then.
da
Aggiungi la tua risposta
Jonas Paarup sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 129
