Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
Cannot slide to unlock screen
Phone will not unlock, there is no password, it just will not slide to unlock. it wasn't dropped, wet or anything else. My settings are supposed to come up even when screen is locked but that isn't working either.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione prescelta
Sounds like a faulty digitizer. Is it responding to your touch at all? If not, you can check the connections, maybe clean them with some isopropyl alcohol on a cotton swab.
If it still doesn't work after that, you'll probably have to replace the digitizer. You can choose between this: iPhone 5c LCD and Digitizer which would require you to switch out the home button and front camera, or you can buy this: iPhone 5c Screen with the home button and front camera included.
Immagine Replace a screen compatible with iPhone 5c. Includes all of the small parts preinstalled in the assembly. 4 inch 640 x 1136 pixel LCD Display, Front Glass Digitizer Panel, Front Camera, Earpiece Speaker, LCD Shield Plate.
Prodotto
iPhone 5c Screen
$34.99
Immagine Replace a scratched or cracked front glass digitizer panel or malfunctioning 4.0 inch 640 x 1136 pixel IPS LCD compatible with the iPhone 5c.
Prodotto
$39.99
Punteggio 2
First before you take apart the iPhone like its stated below try the simple thing that's most likely to work try a hard reset..
Hold power button and home button together for 7 seconds then let go of home but keep pressing power this will restart and hopefully the touch will work
Punteggio 2
Aggiungi la tua risposta
Nelia sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 10
Tutti i Tempi: 432
