Salta al contenuto principale
Guide di riparazione e supporto per la tua Apple Wireless Keyboard. Connetti e controlla il tuo computer Apple in modalità wireless.
Why "k" key doesn't function?
Hi, the "k" letter of my keyboard is dead, I tried connecting my keyboard to two different machines (Mac and Win) with the same results. I tried to take the key off and clean it, but nothing changed.
Any ideas??
Thanks
Questa è una buona domanda?
Punteggio 5
2 Commenti
I have 3 original Apple wired keyboards all with a malfunctioning K key - typing anything with a "k" included needs visual check to ensure it appears... otherwise its repeated tapping to get a response.
da Condividi
Had the same problem with letter Y...if it' not a software issue like speech dictation or similar, or mechanical issue like spilled liquid try removing the cap of the letter than adjusting the rubber connector...than take a pointy object and try pushing the key and gently adjusting the rubber connector. It has worked for me
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
Here's the only solution I could find to a single malfunctioning key on that particular keyboard: http://www.omninerd.com/articles/Apple_C...
Punteggio 4
3 Commenti:
Thanks Mayer, I only press the k key, but nothing happen, upper o lower case is the same.
Thanks a lot
da Condividi
Thanks
da Condividi
That site appears to have been hijacked.
da Condividi
Aggiungi la tua risposta
mvmarroquin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 29
Tutti i Tempi: 19,068
