My touchscreen wont work on my iPhone 5c.
After 2 screen replacements my iphone will still not work. I need to know what else could be the problem for this catastrophe.
Questa è una buona domanda?
mattaposey, this can be caused by a bad digitizer connector. As you can see the connector lacks metal ends and this is what makes it a weak connector. It is easily possible to damage the connector by mis-aligning the digitizer connector
like this. Check the ends of the connector. The plastic of the connector has been compressed into the connector, causing it to flare out and preventing from making proper contact.
How do you fix it if this happens?
I used a very small needle to reshape the inside of the connector
It can possibly be damaged port located on logic board
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 203
