If I got you right, when you connect the iPod to your computer, the computer sees it.
However, you cannot see anything on the screen. Right?
- If yes, then for the sake of it, try to hard reboot your iPod (press and hold Power Button + Home Button together for ~12 seconds. If you see nothing still, press on the power button to restart it).
- If rebooting doesn't help. you either have a bad screen, or the screen cable is disconnected from the board.
Follow this guide to disconnect then reseat the LCD connector. Then reboot your iPod. If that doesn't help, replace the screen.
The guide has the needed steps, tools, and links. But note that this particular repair is not hard, but a PIA in some ways.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
