Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Touch ID no longer works after screen replacement
After replacing the front panel screen, the touch ID no longer works. The home button works, just not the touch features. Setup of fingerprints immediately goes to a "failed" message. Can this be reset? Or, did something go wrong with the screen installation?
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Did you transfer the original home button to the new display?
da
Yes. Original home button.
da
Try a hard reboot by holding the power button and the home button until it reboots.
da
Aggiungi un commento
3 Risposte
No, there is nothing goes wrong with the installation. You have to reset the fingerprint after screen replacement.
Punteggio 0
Did the answer of Sophia work for you Jeff?
Punteggio 0
1 Commento:
Nope. She must have misunderstood. Touch ID won't even set itself up.
da
Try and restore the phone, its very possible the touch ID got damaged but usually a restore helps
Punteggio 0
2 Commenti:
Dis restore worked for any of you?
da
I honestly don't know what I'm doing that's so different than everyone else, but I never have to do anything after a screen swap on a 6. Heck...I just did one this morning and even ran an iOS update after to make sure I didn't get errors.
The most I've had to do was reboot a 5S a year or two ago because Touch ID glitched. That's the only one I can remember even needing to do that on.
da
Aggiungi la tua risposta
Jeff Seitz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 230
