Salta al contenuto principale
High-end gaming laptops produced by Alienware (a subsidiary of Dell since 2006).
Why is my alienware M17X display flickering
Hello,
I have a M17X laptop from late 2013. My display is flickering when moved in different orientations. Initially i thought it was a screen issue so i disconnected the power and display connection to the screen. After cleaning and reseating the issue still occurred. Could it be a loose or defective cable in the screen or could it be a issue with the video card?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes . you are correct, fault con be coming from Video card, LCD cable and LCD as well
Trace it,
  • Check the graphic configuration set it to default level and see whats going on if same fault observed,
  • Connect you M17X to external Display and check any sign of flickering
if yes - fault coming from your Graphic chip
if no - you can determined LCD or Display cable make the trouble and both of coming together and you can the Display with cable
Punteggio 2
1 Commento:
Buddhika,
Thank you for the confirmation. I had re assembled the LCD and remounted it to confirm the fix was not GPU related.
Thank you,
Phil
da
Aggiungi la tua risposta
psortino2007 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 7,131
