Salta al contenuto principale
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Difference between ipad mini lcd and ipad mini 2 lcd
Hi, I have a bunch of iPad mini LCD's and I'm curious if there are any physical differences (not talking about resolution here) between ipad mini and mini 2 LCD's? I have a lot to go through so any difference that I can quickly glance at would be very helpful.
Thanks.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I've found a difference.
If you're looking at the LCD from the back there is a small cable on the right.
On the Retina displays the cable comes up from the bottom of the display.
On the non-retina displays the cable comes from the side of the panel.
Punteggio 2
1 Commento:
Would like a photo if possible
da
You know, I'm pretty sure you're right. But while looking for both images to show side by side, Google shows both the ribbons the same. I did notice the strip across the bottom missing from the mini1. Tho I can currently only vouch for the mini2 in front of me.
-Both of these images are from a Google search result. I am not the photographer. All credit goes to them, and all that jazz.
Punteggio 0
Aggiungi la tua risposta
RegencyTech sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,612
