How do I perform a hard restart?
My tablet isn't working correctly and has trouble booting up, I was wondering how to wipe everything and restart it.
Questa è una buona domanda?
Trouble with Reset
If protection software does not correct the problem, on the back of the 4Sight there is a small hole that is labeled "Reset". Using a pen or a paperclip, insert the tool into the reset hole and you will fell a slight depress of the button inside. Pull the tool out of the reset hole and the device should be powering back on.
Trouble with Hard Reset
To proceed with a hard reset, there are several options for Android powered devices. Hold the "Up Volume" button on the side of the tablet, while holding the power button, this should start the reset process. If this does not work, you can try, holding the "Down Volume" button and the power button.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,654
