Salta al contenuto principale
Guide per lo smontaggio e la riparazione dei computer Macintosh di Apple.
42814 Domande Visualizza tutte
Photoshop unexpected quit at statrtup
After opening an image from the web, Photoshop quits at startup. Have deinstalled, cleaned caches, reinstalled, no change.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Corrupt
.plist files often cause strange application behaviors.
Delte any user/library/preferences - pshop .plist files.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Punteggio 1
1 Commento:
One of the first actions I took was to delete Adobe.com.Photoshop.plist from the prefs folder. No effect whatsoever. Thanks for the input, I would have probably answered the same where I to read of someone else's same problem.
da
At such unexpected quit some data usually can be crashed, you may check it up with how we fix photoshop corrupted file?
http://www.photoshop.fixtoolboxx.com
Punteggio 0
Aggiungi la tua risposta
Terry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 838
