Salta al contenuto principale
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Domande Visualizza tutte
Upgrading to 3GB RAM - order to insert RAM?
I'm upgrading from 2GB to the max 3GB RAM for my iMac 2118.
So I will be replacing one of the existing 1 GB chips with the new 2GB chip.
Does it make a difference a) which 1GB chip I replace or b) which of the two slots I install the new 2GB chip?
Thanks.
David B
Questa è una buona domanda?
Punteggio 4
1 Commento
+ well stated question
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No, it does not make a difference. Just make sure you properly seat the new RAM in it's position and you will be fine.
Punteggio 3
2 Commenti:
+ agreed
da
+ Ralph
da
Can you mix 2 different of RAM? Or is it better to take 2x2GB?
Punteggio 0
Aggiungi la tua risposta
David Brandwein sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 6,840
