Salta al contenuto principale
Un'unità disco ottico uscita nell'aprile 2009, identificata dal numero di modello iHAS324.
Why won't my disk eject?
Every time I try to eject the disk from the drive, the tray fails to eject. When I press the eject button a motor sound is heard, but the tray fails to open.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione prescelta
There may be a disk jammed in the device. You can try and manually open the drive but be careful as the tray may break. Or you might have to take apart the device and replace the disk tray belt.
Punteggio 0
Risposta più utile
It won't read, won't stay open, and won't eject. It's probably 5 years old. CDW sells it for $19.99. If blowing it out with compressed air doesn't fix it, you have to ask how much your time is worth.
http://www.cdw.com/shop/products/LiteOn-...
Punteggio 1
1 Commento:
See if there is a small hole above the eject button. Use a straightened out paper clip inserted into the hole to manually eject the tray. This takes a bit of force sometimes. Sorry, I just realized that this is a school project question.
da
Questa risposta era destinata originariamente a un'altra domanda.
If the disk tray will not open and remain open, you may need to replace the eject button.
Punteggio 0
No No No,
Drive Belt slipping,
I could not find a replacement.
Lite-On is known for this on quite a few of their drives.
Various remedies online are:
1. place belt in boiling water (supposed to shrink belt).
2. use drive belt conditioner.
Punteggio 0
Aggiungi la tua risposta
Nick sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 32
Tutti i Tempi: 1,617
