Salta al contenuto principale
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Domande Visualizza tutte
How do I open my passenger door on my Mercedes 300D?
My passenger door to my 1977 Mercedes 300D won't open, even though the power locks work fine on the other 3 doors and they open just perfectly. The vacuum system is working fine but I think it is a opening mechanism within the door has failed.
So how do you open the door to replace the broken part, without butchering the door panel completely. I realize that the door panel is relatively easy to remove if you can open the door. However since that is not possible what would be the recommended approach.?
Open for suggestions
Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you are saying that the passenger door won't unlock with the vacuum system, you can simply pull up on the knob manually then open the door. The door locks all can be worked manually, as a backup for when vacuum fails.
If instead you are saying that the door is UNlocked and yet it still won't open the latch mechanism may simply be stuck. This is an unusual problem, one I haven't heard before. Even W123's that have been in bad head-on accidents that I find at the scrap yard have all their doors still working. If indeed it's unlocked and stuck, then one thing you can try is to simply put more force on opening the door from the outside. The outer door handles are designed to be pulled with a lot of force - the idea is that, in the chance that a bad accident causes a door to deform and get stuck, a rescue crew can strap the door handle to a winch and pull the door open. That's why they are "pull out" style instead of "pull up" style like most door handles you see on cars - ease of opening during emergency situations. While I'm not suggesting you do this with a winch, you can try tying a strap to the handle and putting all your weight body weight in to it. It won't hurt anything.
If all else fails you can remove the seat using the seat removal DIY guide to make access a bit easier.
Good luck and don't hesitate to be in touch if you need more help. My email address is in my profile.
Punteggio 2
1 Commento:
Seems like using a dremmel tool to cut thru the panel, others suggest You destroy, and get at the BROKEN part or linkage that can be pulled—-a better idea—-I will try PULLING with major Man force-1st. Thanks for info, Gary
da
Aggiungi la tua risposta
Darryl Poturalski sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 461
