Salta al contenuto principale
Krups single trigger coffee grinder identified as style F203.
motor works but blades only spin if grinder is unloaded
The machine seems as if it's working with no load or with very small amount, but as soon as I put in a normal amount of material to be ground then the blades do not turn. It's like whatever connects the blades to the spinning shaft has failed or does not engage properly. Also how do I get the blades off?
Questa è una buona domanda?
Punteggio 4
1 Commento
The blade screw is stripped. I have the same problem. I can’t find a replacement blade.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
the blades can be pulled off, pull hard,because the thread inside the plastic blade hub has stripped. Penny pinching on Krups part! you will now have to glue the blade back in place-epoxy resin worked for me.
Punteggio 3
3 Commenti:
Worked a treat, many thanks.
da
Easy fix that worked. Thank you
da
Worked Great!! Thanks!!
da
Aggiungi la tua risposta
tanya sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,911
