Salta al contenuto principale
Repair guides and support for your LG TV.
1341 Domande Visualizza tutte
HDMI ports on the back of the TV have pushed in!
Hello:
I have an LG47LN5750 and while swapping out my Playstaion 4 with the Nintendo Wii u, the HDMI port was pushed into the casing of the TV.
I then attempted to use HDMI 2 and the same thing happend.
Luckily, HDMI 3 worked without incident. I have swapped out other components before so I am not sure if I wore out what holds the port in place or whatever.
Is there a way that I can just remove the back case to this TV and put them back?
What is holding them in place?
Thanks for any help,
Paul
Questa è una buona domanda?
Punteggio 6
11 Commenti
Please, smart guys (or gals) help us with this question. i think I see a way in to reset the HDMI input but am not sure about it. Thanks to all. es335 John Brown
da
take apart the tv and take a picture of the board were the HDMI is and we will see what is best for the repair. please be patient for a reply.
da
Hi there, if you can take the back cover off and see what has happened when you pushed connector in, might be able to push it back into place if it has not damaged the PCB is mounted to it. If it has a cable on the back you might have damaged the clips that hold it into the back casing. If that's the case you might be able to epoxy it connector into place. if you have pushed PCB back see if you can use some rubber or plastic to provide a support spacer to hold it into position. You need to open it up and see whats what. Regards
da
I have just pushed in My hdmi input I have 60inch tv is is possible to fix it.
da
I fixed mine by watching a youtube video. I had never done anything like this before so it was a bit nerve racking in a way.
I had to purchase the "logic board" of my LG 47" (about $60.00) beforehand.
The part that breaks or pushes in, is not all that secure so if you do open it and get a chance to look you will see what I am talking about.
Hope this helps,
da
Mostra altri 6 commenti
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Hi Paul,
So I would simply take the TV apart. Then you can look at the mainboard and see if it needs to be replaced. I am going to assume it does BUT it may not and the mounting bracket could have just come loose.
This is where the mainboard should be on your TV if you provided the correct information. Outlined in orange.
This is an image of where you will find the label for the MAINBOARD part number a simple google for this and you should find it pretty easy and cheap. It is not that uncommon for this to hapce. Outlined in Orange.
Some sidenotes it do not rest your hands on anything inside the TV as you may cause damage to your set. Also, wear gloves if possible (latex) this will aid in keep oils/moisture from your skin getting on components.
Hopefully you just need to reattach the plate.
Best of luck, hope this helps.
Punteggio 4
Risposta Più Utile
your best bet is to open the TV and see what has come loose. if you lucky it is either a metal casing soldered to the PCB or a plastic casing thats broken. If this is the case and you are capable you can solder it back onto the board or glue plastic casing. Just take care that you dont induce any static into the board as you could blow some of the LSI chips on the board. then reverse the order you took it apart. Best if you strip, take a photo every step of the way so you dont end up with spares once you have closed up again. Good Luck
Punteggio 5
1 Commento:
If the HDMI port is broken, is there somewhere I can get that part & fix it?
da
Where it's possible to buy hdmi port for the tv ? Hdmi port female with 21 pin vertical 180° for to solder and repair the hdmi connector. I search it but only 19 pin i see in the web! :(
Punteggio 1
2 Commenti:
I had this issue I had to replace the whole Mother Board i had two fallen in they are very difficult to repair
da
I can't find the spare. Do you know where to buy it?
da
i had the same issue i ended up with a new main board
Punteggio 0
2 Commenti:
We’ll mine just popped in three of them took of back nothing broken but how do I put them back in
da
Can someone tell me how to put them back in
da
Aggiungi la tua risposta
Paul Squillace sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 89
Ultimi 30 Giorni: 363
Tutti i Tempi: 87,267
