Salta al contenuto principale
The Honor 3C is an Android smartphone produced by Huawei and released in December 2013 for 3G, April 2014 for 4G, and August 2014 for 3C Play. The Honor 3C can be identified by model numbers H30-T00 and H30-U10.
33 Domande Visualizza tutte
How can I replace the camera lens on the huawei honor 3c?
i just bought my honor 3 phone last year somewhere in September, but a few month back i did notice that my picture that i took using my phone rear camera quite blur then i notice that my camera lens scratch a little bit. since it makes my photo become blur i decided to find the replacement camera lens and i found one on ebay, but the problem is, i dont know how to change the lens, i did try to search but no documented tutorial available. i hope someone could help here. tq
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
You have to remove the white back cover, SIM cards and MicroSD.
You will see a bunch of phillips head screws on the black internal plastic, one of them is covered with self-adhesive paper, pay attention to remove that screw too.
After removing all the screws you have to carefully take the middle black cover and the front part of the phone apart.
Although the black plastic is flexible, you have to be careful, not to break it. You can use a plastic card, or special tool for disassembly.
After removing the middle black cover, you can push out the lens from the inside, it is only fastened with a double sided tape.
You can buy replacement lens from Aliexpress.
Although it is also possible to remove the lens without disassembly, only by lifting up it's edge with a very thin flat screwdriver, I am not recommending it, as this will certainly damage the chrome frame.
Punteggio 1
1 Commento:
tq very much ! did manage change my lens, using your tutorial csabak :) now i can use my rear camera again.. tq very much..
very good and clear tutorial,
funny moment is i had my hard time to find the screws that covered with self-adhesive paper..hahaha but everything work just fine once i found it.. tq once again mr . :)
da
I don't know. I need to replace my lens too.
Punteggio 0
I am from Malaysia. I need to change my lens too. Bad picture quality with the scratches lens. H30-U10'''bold text'''
Punteggio 0
2 Commenti:
i did buy the lens from ebay, it will cost u around RM 50+- :)
da
i didn't found it.
da
do just as what “csabak” told, and add pictures to explain.
Punteggio 0
1 Commento:
how can i uploading my picture successfully?
da
Aggiungi la tua risposta
iddinordin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,530
