Salta al contenuto principale
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
broke the power button flex cable
hi,
i snapped the thin flex cable for the power button when trying to replace the screen. is there a part i can replace? or will soldering work?
Questa è una buona domanda?
Punteggio 3
1 Commento
I have this same issue. I have ordered a replacement cable. Does it require soldering or will it just clip into place?
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Soldering skills of medium level will be required and a good iron with small tip (silver bearing (preferred) solder with good non acid flux as well). I would not advise anyone who does not have those skills to attempt repair unless you don't mind F@i& up the whole board. The ribbon can be bought online but it does require soldering.
Punteggio 3
oneplus one power flex cable
http://www.aliexpress.com/store/product/...
Punteggio 1
I did the same thing so I would be interested if you found a workaround
Punteggio 0
Aggiungi la tua risposta
Damon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,769
