How can I tell?
I can't tell if I have a banana or avocado or maybe a dog? I might even have a mink pelt. I just wish there was a way to see if what I was holding and attempting to eat is actually a banana.
Questa è una buona domanda?
In case you are blind, bring in a monkey, wait 5 minutes, feel for which item is missing.
What if it were a plantain?
Then it wouldn't be a banana.
Does the device emit a sound of any kind (while stationary)? Does it appear to have an on/off switch?
If it makes a sound, or has an on/off switch, it is NOT a banana.
is there a way you can post a picture of the device? it could be any of those. What are the specifications? or is it a knock off?
Bit in if it bits back it was the dog
Just make sure that the device is yellow and crescent moon shaped. If it has legs, then it's probably not edible in that state. If it's green, it may be an avocado. Hope this helps...
if its green it also could be a cucumber, lime, or even a plantain. There are many options.
All of these green options are edible, however a lime is incredibly sour, and the anti-opening device in the lime will cause temporary blindness if the fluid is caught in the idea. A cucumber is extremely ovular. A plantain looks like a banana, but you may encounter bitterness. This is the anti-opening device.
the blindness will come from a lemon that has been died green.
That’s dyed green.
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 19
Tutti i Tempi: 534
