Salta al contenuto principale
Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
75 Domande Visualizza tutte
Domanda Chiusa
Which type of adhesive tape for front display?
I can´t see in the guide for replacing screen what type of adhesiv i should use for the new display to secure water proof?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
The new screen should already have the adhesive applied to it. If not, then you will need 3M 300LSE Double Sided Adhesive. You can buy it by the roll which comes in different widths from 1mm up to 12mm here is a link to some http://www.ebay.com/itm/261807573229?_tr.... Or you can buy a sheet of it that comes in many sizes also, here is a 4"x8" sheet http://www.ebay.com/itm/3M-300LSE-Double.... You can also search for sheets that are specifically cut for your device.
Punteggio 1
You will need a special two sided stick tape for the front display. You can find it on line pretty much anywhere. Most everything I found was either 5mm wide or 2mm wide.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,568
