Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Domande Visualizza tutte
Display winking on and off?
Hi everyone.
I'm having a really annoying problem with my Macbook. This problem involves the LCD, that blinks if the lid is moved up or down.
To make it stop blinking I need to find a right angle of the lid or to press in the corners on the bottom right or left of the display.
Could it be the LVDS cable?
Questa è una buona domanda?
Punteggio -1
1 Commento
Looks like the screen is broken... you might need to replace it. Not gonna be cheap though.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
In most cases when moving the screen causes image glitches like this it is due to a faulty LVDS cable. However, the non-digital looking yellow fade in the corners would indicate an LCD failure.
Punteggio 1
1 Commento:
The yellow faded corners are a mistake that I did using the heat gun to remove the front glass.
Thank you for the answer! :)
da
Aggiungi la tua risposta
robbitara sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 108
