Salta al contenuto principale
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Domande Visualizza tutte
Where does the rubber plug inside of filler door drain to?
1978 mercedes w123 diesel. Inside of fuel door is a rubber plug conical in shape.
does it drain rain water to the outside or does it have another function? threaded plastic weed wacker line to see if i could find the exit area and I did not see it.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It also covers over filling or expansion of gasoline.
Punteggio 2
Drains to outside below rr fender. If you cannot see your wacker line, the rubber tube may be separated or torn. Push your line as far as you can then reach up inside the fender and feel for it.
Punteggio 0
Aggiungi la tua risposta
mike anthony sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 424
