Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
Missing what I think is a Resistor but not sure exactly.
Ok so I have a water damaged IPhone 5c . I disassembled and cleaned with 99% alcohol but still nothing so i proceeded to remove the Metal shields where i found more corrosion which i cleaned with a brush and alcohol .
After cleaning i reassembled with a new battery . The phone shows no signs of life other than the board gets hot enough to burn in this area SHOWN IN BLACK .
Now i noticed that what looks like a resistor but is probably not was covered in corrosion and looked damaged and seemed to be the source of the heat. would burn finger when touched. So i successfully desoldered it and no more heat but still no life in the phone. I'm looking to find out what this part is called so i can get a replacement to see if it solves the issue.
Part shown in black
These images were taken from ifixit i just highlighted the part i am referring to.
Thank you in advanced.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
st3v3w, that is reference designator L11 which is a 2.2UH-20%-1.7A-200MOHM inductor (coil). It is listed as a TFA201610G which is manufactured by TDK
Punteggio 1
9 Commenti:
Thank you oldturkey03 your knowledge is greatly appreciated.
da
Sorry to bother you again but i have been looking for this part but seem to be having trouble find it . do you have any recommendations as to where i could find it?
da
Where in the world are you located?
da
Canada , New Brunswick .
da
Lets see if we can find the right component. If you can, measure the components physical size. That way we could find an equivalent package size. I'd try to check Murata's LQM2HPN2R2MGH and see if the dimensions would be workable. You doing okay with all the snow and bad weather?
da
Mostra altri 4 commenti
Aggiungi la tua risposta
st3v3w sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 161
