How do I access the batteries in the car?
Do I need to remove the car shell, or can the compartment be found underneath the car?
Questa è una buona domanda?
The batteries in the car are located between the two rear wheels on the car. They are covered by a plastic casing, which is held on by a screw. The screw can be unscrewed using a Phillips PH0 screwdriver and turning it counterclockwise.
For step by step instructions, please refer to the Car Batteries Replacement guide.
When you replace the batteries, be sure to insert them in the correct orientation or your car will not turn on again.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 113
