Salta al contenuto principale
Repair and disassembly guides for garage door openers.
18 Domande Visualizza tutte
remote opener works close up - but no range
T/S progress so far:
New battery and several different remote control - same result
- can control with wall switch but remote more than two feet away does not work - works within one to two feet.
- suspect receiver circuit in opener - maybe front end not working.
can't find schematics to get in deeper and replace failed component. Any help appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Check your drive unit (on the ceiling). See if there is a small wire hanging down from it. That is the receiver's antenna. If the wire is there, be sure it is attached. Some models don't have an exposed antenna. http://ep.yimg.com/ty/cdn/linear-access-...
Punteggio 2
Aggiungi la tua risposta
patrickmoretti sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 246
