Salta al contenuto principale
Mid 2014 / Intel Core i3 / 500GB Hard Drive
Why is my device not turning on?
I recently have been unable to turn on my laptop. I have used it a lot recently but now it won't turn on.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
5 Risposte
Soluzione Prescelta
The device's battery may enough of a charge to turn on, and function properly. The battery may not be fully charged. Try plugging the charger into the device to see if this was the case. If this was not the case, you may have a faulty battery. One way to check is to remove the battery, and then try to turn on your TouchSmart with the charger plugged in. If the device turns on without the battery, the battery is the cause.
If you have any further questions, here is a link to the troubleshooting guide for your device: HP TouchSmart 15-r015dx Troubleshooting
Punteggio 5
1 Commento:
Thanks for your help!
da
In a first site it looks that there is a problem of battery. To check battery is faulty or not just remove battery and then connect directly. If still your laptop not started then there is lots of other reason. If your laptop’s BIOS screen not showing then remove and insert RAM, may be this will work. Join laptop repairing institute for good knowledge of repairing.
Punteggio 1
The next day the laptop didn't even boot up, the fans were whirring but not the BIOS screen came up. The CAPS lock button is blinking in intervals of two, the wireless button is orange and thats it. Its been like this ever since. Any suggestions? Please! T
Punteggio 0
have same problem here
Punteggio 0
1 Commento:
all the hardware seems to run except the screen and anything is possible...
da
My computer comes on but it is the windows insignia and then it freezes up. What do I need to do to fix it.
Punteggio 0
Aggiungi la tua risposta
Jacob Kleinsorge sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,778
