Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Spanned screw, how to remove them?
Hello I was following the guide for updating my mid 2012 13" Mbp to a dual drive when I spanned the screw of the optical drive due to a lack of space between the screwdriver and the optical drive itself.
Any tips of how to remove them?
Step 14
Installazione doppio hard drive nel MacBook Pro Unibody da 13", versione metà 2012
Questa è una buona domanda?
Punteggio -1
2 Commenti:
What do you mean by 'spanned'?? Did you break off the head of the screw or did you strip-out the head so a screwdriver can't turn the screw? Also did you use the correct screwdriver?
da
Jesus that's a late reply by my side thought nobody ever replied.
Head of the screw was broken. Yes I used the right screwdirver but both screws closer to the outer edge of the laptop got borken. Got to buy a dremel to remove them.
Thanks!
da
Aggiungi un commento
1 Risposta
You might be able to use one of these sets from iFixit store or similar:
Precision Screw Extractor Set
Immagine Precision Screw Extractor Set
Prodotto
$24.99
Punteggio 0
Aggiungi la tua risposta
andreabonomelli sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 505
