Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Domanda Chiusa
Overheating and glitches on iPhone 5s
I dropped my iPhone 5s in the toilet. Took it out real quick and left it to dry for a few days. Once I plugged it and turned it on, I noticed the screen glitching pretty bad like someone else was touching it, and the battery not charging but overheating over time. I replaced the screen and the battery thinking that might do the trick. But the battery still overheats and the screen glitches when the phone is starting to get hot. I cleaned everything really well but everything is still the same. What should I do next?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would suggest doing a DIY water damage repair. Water damage needs the logic board to be cleaned thoroughly and not even this guarantees a solution. The sooner you get onto water damage the better the outcome.
Here is a link: iPhone 5 water damage repair
Please note - this is no guarantee and you still may have the same issues. The big issue for you is that water damage tends to manifest and get worse so I suggest you BACKUP your data ASAP! By plugging into iTunes.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 290
