Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
How can I fix my Laptop Screen from wobbling?
The Black hinge cover is damaged and when i touch my screen to move it to a different position it wobbles back to the original.
It is not under warranty and I'm looking to do it myself if possible.
Questa è una buona domanda?
Punteggio 2
3 Commenti
What are the last 4 figures of your serial number?
da
The last 4 are DTY4.
da
Apple MacBook Pro "Core i7" 2.9 13" Mid-2012 Specs
Identifiers: Mid-2012 13" - MD102LL/A - MacBookPro9,2 - A1278 - 2554*
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Go through this guide and look especially at step #13. Sostituzione schermo MacBook Pro 13" Unibody metà 2012
There are 3 screws on each hinge that you need to check and possibly tighten.
Punteggio 3
2 Commenti:
Thank you I'll try it out. I start from the beginning i presume?
da
No, just open it up and go straight to the screws. Be careful that the screen is aligned before you lock it place. Do one screw at at time, then check it. Check to see if any are loose, do one on the right then one one the left checking to see if it closes correctly. The first two you tighten will probably lock it down.
da
I found this online and it may help resolve your issue
https://www.youtube.com/watch?v=D8BixdIB...
Punteggio 1
1 Commento:
Thank you for your effort ,but my mackbook pro model doesn't look like beneath the casing.
da
Aggiungi la tua risposta
Ali sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 14,836
